Max Backes - Single Tracks
Max Backes is a composer from Krijevci, Croatia. Together with his compatriot and countryman Krunoslav Paic, he created tracks as part of their main project Galactic Warriors, as well as third-party ones - Neon Dance and Retrobeat. Well, he releases his solo compositions both under his real name and in the framework of the Multi Kosmos project. This topic contains his single tracks, so I suggest you listen to them!
The release dates of the Multi Kozmos themes are unknown. Apparently, they appeared in the early 2010s.
As Max Backes, respectively, he presents on the Space Holidays collection since volume 4:
Re: Max Backes - Single Tracks
Max Backes - Space Defender Project (Mix by Space Intruder, Edit 2k19) 343212
Track List:
Multi Kozmos - Space Forces (Remastered Extended Vers. by Space Intruder, Edit 2k19) 354777654
Max Backes - Return Of Hope (DiscoBoy NRG CUT - IX) [Extended Version by Schefler Tibor] 343212
Return to “Max Backes”
