Releases and promotion August 2023
Forum for promotional stuff; the last post will be displayed on the portal.
Re: Releases and promotion August 2023
Galspace Project - Spacesynth (Uralbroter's Mix) [published on 11.08.2023] 6546758
Firage - Laser Lords (released on 11.08.2023) ✅
Description: "A little Spacesynth / Italo Disco style tune, mainly inspired by the music of Koto & Laserdance but also by some other tracker musicians like Lizardking and MyVoice. Most synth sounds made with Synth1, some with Korg M1 VST, samples from various sources e.g. LinnDrum, E-mu Emax".
VA - Spacesynth Disco (Classic Mix Respect) [published on 12.08.2023] 🎶
Spacehawk - The set created from the composer's themes (published on 12.08.2023) 98459684378
Angelic Synthesis - Cyber Falcon (released on 14.08.2023) 🐦
Corbyn Lowers, the creator, wrote: "The first song of the new project is available for listening!" So let's welcome this new good initiative of the composer and sincerely wish him stable development & further success! 😊
Polish composer and producer Tomasz Oleszko, better known to us as DJ CON-T, posted all his early singles and releases on the Bandcamp online store, including the latest albums "My Dreams" & "Beyond Orbit" of joint projects "Italo Emotion" & "Stellaris" released by the Italo Box Music label. On the store's page, you can listen to these works and, if desired, purchase them for yourself in a digital format in high quality: https://djcon-t.bandcamp.com/music.
Lancers DJ - Select n°426 (SpaceSynth Mix) [published on 19.08.2023] 👏
JWPH / Derivakat & Netrum - Cycle (Spacesynth'd Tracker Remix) [released on 20.08.2023] 👌
Pixell — Spacesynth Mix Phonetic (published on 20.08.2023) 🔊
Sinto Brass - Tracker music DJ mix @ Demodulation 2023 (published on 15.08.2023) 354777654
Rawbotic - In The Space (Promo by Van Der Koy) [published on 21.08.2023] 🌌
Galactic Warriors - The Best Of (Spacesynth Megamix) [published on 22.08.2023] 343212
Sinto Brass - Spacesynth Mix #5 (published on 24.08.2023) ⭐
Robert Górski - Italo 🇮🇹 Space Synth Vol. 81 (published on 20.08.2023) :hi:
JSC – Italo Space Disco Planet (published on 26.08.2023) 90835469836
